A
AC Question
I have a Sprint Galaxy S3 (SPH-L710) worked great until it was dropped. Powered itself off and won't power on or charge. I have tried several things and nothing seems to be working. I tried removing the battery and reinstalling it and it would vibrate go to the Samsung logo and shut off. Power switch doesn't seem to work. I tried plugging the charger in and it does nothing. I remove the battery and plug in the charger and the red light comes on, but when I reinstall battery it goes off. I have tried removing battery and holding down power switch for 1 minute then reinstalling battery and it will do the same thing, vibrate and stop at Samsung logo and shut off. I tried removing battery and when reinstalling it hold down the home key and volume+ key and it will say loading recovery but then shut back off. The repair store where I live said it needed a new LCD Display and Digitizer??? I shouldn't be able to see the Samsung logo screen, Correct? I need to power on phone to remove some files and photos, Can this be done??? Please Help!
