Is there a workaround for lollipop not connecting to wifi without an ip connection?
Sony z3 compact. Using various apps, especially iRegatta, which needs a wifi link, but android wont connect to network as no Internet connection.
Thanks
Re: Is there a workaround for lollipop not connecting to wifi without an ip connection?
Welcome to Android Central! Are you just trying to connect to your local WLAN to communicate with other devices on the network? Or is the wi-fi network supposed to have an internet connection, but you're just not able to get it?
