1. AC Question's Avatar
    I just got the phone and I'm not sure how long the battery should last. I fully charged it and its been running for 46 minutes and i went from 100 to 87. My brightness is low, my wifi is on, location is off. I'm not sure if this is good or normal? I have 8 hours and 42 minutes left according to the system. I have not used the internet yet or anything else that would drain the battery like this? Is this how it is for everyone or is this a problem that needs to be addressed? Is there anything I can to do(besides power saving mode) to save more battery?
    09-03-2015 11:38 PM
  2. nahoku's Avatar
    I recommend you join the forum so you can participate in conversations/posting. HERE is the battery thread in the Not 5 forums. It's possible your questions will be answered there.
    belodion likes this.
    09-04-2015 12:22 AM
  1. Note 4 extended battery w/ DIY case
    By bluerror in forum Samsung Galaxy Note 4 Accessories
    Last Post: 11-07-2018, 12:54 AM
  2. Why is my Nexus screen purple?
    By chapter3 in forum Google Nexus 6
    Last Post: 09-04-2015, 03:15 PM
  3. Is OK Google supposed to work with the screen off?
    By Blipstein in forum Samsung Galaxy S6 edge+
    Last Post: 09-04-2015, 03:05 PM
  4. Replies: 4
    Last Post: 09-04-2015, 11:51 AM
  5. My Galaxy Mega 2 did not update to the 5.1.1 why?? And how can I fix it?
    By AC Question in forum Samsung Galaxy Mega 6.3
    Last Post: 09-04-2015, 12:54 AM
