Welcome to Android Central! Same problem as what? Keep in mind that we don't know which post you may be referring to.
Does the phone charge normally when plugged into a wall outlet? Let it charge for at least 4 hrs without disturbing it, then try to power on again. If it still doesn't work, try a different USB cable or charging plug.
Does the phone have a removable battery? If so, try a new or different battery.
