Still have echo with turning on the noise reductions?
A
AC Question
Need help I am having and echo on calls. I can only hear myself and it gets annoy. I have turned off the noise reduction and reset the phone but nothing helps..... Need help please !!!!!!!
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Turn the volume down. If that doesn't do it, check with your carrier. (They can be causing echo on the backhaul (the link from the tower to the telephone system).
