My lg Optimus Fuel Screen has a system error.
A
AC Question
my lg Optims Fuel phone will not charge , will not turn off. will only show a system error on the screen . That is all it will do
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,536
4,674
113
Welcome to Android Central! What does the system error say or look like? If the screen is frozen on it, remove the battery for 10 seconds, then reinsert it and try powering back on again. If you keep getting the same error, then either the firmware is corrupt or the motherboard has failed. It'll be hard to fix either by yourself. Bring it to a repair shop.
dumpsterrentals37
