I plug my charger in and I get the bolt and does not go past this point but when I switch my phone on it immediately turns off as there is 0% battery, can anyone help or has anyone encountered this and fixed it?
Try charging other phone with your charger. Even if the other phone shows it's charging wait for a while and observe: is it charging normally? (If the charging icon shows but it doesn't seem to increase battery percentage for a while then maybe it's your charger).
However if you have made sure your charger works fine, another thing you can do is use another WORKING charger--see if your phone charges. If it still doesn't then maybe either the charging port or your battery is the issue.
