1. AC Question's Avatar
    The display has refused to leave the screen. Each time i press 'ok', the display returns. I can't operate the phone at all. Whenever i reboot, it returns the same error display. Pls. help me out. Thanks.
    12-17-2015 12:09 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! You might have to try booting into the Recovery Menu, if possible. Power off, then press Power, Vol Up, and Vol Down all at the same time, and hold them until you hopefully see a Recovery Menu. Then select Wipe Cache Partition, and then Reboot System Now. If that doesn't work, then go back to the Recovery Menu and do a Factory Data Reset.
    12-17-2015 06:55 PM
  3. Asuk's Avatar
    How can I fix techno droipad 8H screen and how much does it cost at techno Carl care
    02-01-2017 11:09 AM
  1. Replies: 7
    Last Post: 02-08-2016, 08:31 AM
  2. Replies: 1
    Last Post: 12-17-2015, 01:13 PM
  3. Replies: 1
    Last Post: 12-17-2015, 11:54 AM
  4. How do I print pictures from my S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 12-17-2015, 11:53 AM
  5. Issues with ROM Manager
    By kylestyle123 in forum T-Mobile Samsung Galaxy S4
    Last Post: 12-17-2015, 11:27 AM
