Samsung s6 edge + charges so slow
A
AC Question
Pretty much when i plug my phone into a wall via a fast charge adapter my phone will charge from 0-100% within the hour. However when i do not use the fast charge plug and use a usb port on a computer for example it says it will take 3 hours 27 mins to charge and my phone is on 45%. Is this a common issue? and is there any possible way to make it quicker?
Thank You
the tall guy
Q&A Team
Sep 23, 2013
7,210
Hi, it isn't really a 'common issue' it's more fact - using the fast charger charges the phone fast, not using it doesn't charge it fast. Also. charging the device from a computer usb port will charge slower than any wall adapter as it's using less voltage to charge the device.
