I had two new battery lockscreen problems. Try this. When the lockscreen is displaying, at the bottom of the screen hit the android icon for recent apps, (on my Nexus 5x it's a square on the right). The lockscreen should minimize showing the app it is associated with. Either uninstall the app or check it's settings to disable the battery charging lockscreen. The two apps that were secretly launching my lockscreens were Next Launcher Lite and Kitty Play wallpapers.
