Need help to transfer photos from Motorola Droid RAZ M with Android ver. 4.4.2 OS to its SD card
A
AC Question
I have a Motorola Model Droid RAZR M smartphone using Android version 4.4.2 software and all I want to do is copy the 97 photos on my internal phone storage to the SD card that's plugged into the card slot in the phone. The card is empty as far as I can tell. HELP!
nahoku
3,300
If your phone doesn't have a file manager, try ES File Explorer. You can copy/move files from internal to SD with this app.
I HIGHLY recommend you COPY files and not MOVE them. Verify the copied files are present on your SD before you delete them off your phone storage. Make doubly sure the photos reside on the SD by opening each one of them to make sure they're copied ok. Many people simply move files and during the move, files can get corrupted or lost.
19escape20
