Will my android tablet's data/memory be wiped out if I replace its charging port?
RandomPasserby
Good day, I am planning to get the charging port of my tablet replaced by visiting its manufacturer, but I don't know if the data will still be there once the port is replaced.
Thank you for your reply :D Well, the manufacturer is not well-known ^_^" But the tablet is completely usable in spite of its brand. I got this question because I once had the store repair the tablet's screen, and it got formatted. According to other forums that I've visited, the data won't be affected as long as the logic board isn't involved. Still, I fear that they might format it since some says that if you bring your gadget to the manufacturer or store they will format it no matter what the type of repair it will be.
I'm not so great with this, so may I ask if the charging port will affect the logic board too? :/
Thank you again ^_^
Thoitrangyozu
