Re: How do i change the settings on the volume buttons?
Welcome to the forums!
You may have an app running in the background or connected to another device via Bluetooth. If that's not the problem then reboot the device and see if that clears your problem. The volume button should control the device volume globally (ringtone), unless it's connected to a media device or using a media app.
Let us know how that goes.
