A
AC Question
The initial bluetooth pairing worked absolute fine, and I could use the car's audio system for making/receiving calls. But the next time the connection would not be re-established automatically. The phone shows "connected", but the car's audio system shows "not connected". After switching the phone's bluetooth function on and off several times manually, it then starts working again suddenly. Previously I had used my Galaxy S5 on the same car, without any issues. So I believe it has something to do with Android's new firmware 6.0.1. Any ideas how to fix this problem ?
Thank you !!
Thank you !!
