Less illuminated of the lower-left corner of the screen LG G3?
I bought a LG G3 month ago. As soon as I got home and turned on the phone for the first time, when the phone is turned on, the lower-left corner of the screen was much less illuminated than the rest of the screen.
Actually, imagine a LG G3 screen divided into 4 cubes. The lower-left cube of screen is about 50% less illuminated than the rest of the screen, but all of the functions on the screen are performed without error, just that lower-left cube of screen is 50% less illuminated than the rest of the screen.
It's already happening 3-4 times for last 30 days to me. This problem takes about 1 hour and after about 1 hour, the illuminate of the display back to normal.
I call a servece and they told me that smart phones used to go a little mad, and that's quite normal. I wonder if someone had a problem like me, and is that really normal with smart phones?
Re: Less illuminated of the lower-left corner of the screen LG G3?
I have never heard of that. It sounds like a fault to me.
1 Attachment(s)
Hello, I put this question on forum, and in the meantime I registered at the forum.
I had never heard about this problem too, last 2 days I tried to find something about it but I had no success. I hope that someone will appear here who might know what's going on?
PS: I apologize if I have mistakes in grammar coz I don't know English perfectly !
Edit: Picture of the screen: Attachment 223071
And, on second thought, I think it's breakdown of the screen or erron, not software problem ...
Welcome as a new member. :)
That is certainly abnormal. If the phone was bought new, it ought to be possible to get an exchange or refund from the retailer....or contact LG customer support about a warranty return of the phone, for replacement or repair.
Your English incidentally is very good.
Yes, it was purchased as new. This problem appeared to me ever since I turned on phone for the first time. I will definitely look for a replacement device, coz this certainly can't be a normal thing.
I will not accept service because this is a new phone, and it is apparent that was already with some kind of error when I bought it.
Thank you for your advice and help !
