1. AC Question's Avatar
    Can flash be used as flashlighton the note 5
    04-11-2016 03:10 AM
  2. AlphaTango414's Avatar
    Pull down the notification shade and hit edit at top. There will be a quick toggle for flashlight. Or you can download one of many apps from the play store.
    04-11-2016 03:49 AM
  3. Dd Hh's Avatar
    It doesnt work for my Note 5 (N9208) too after I updated to the latest 6.0.1. Only works when taking a pic or record. When turned on, it will turn off automatically everytime I go to skype or video call. The flashlight option on pull-down, then, becomes greyed out and cant turn it on. It works fine before the update. Pls kindly help with a fix.
    10-30-2016 04:31 AM
  1. Why is my wifi slow on my new s7 edge?
    Last Post: 04-14-2016, 08:14 AM
  2. My lock screen doesn't change automatically in my note edge?
    Last Post: 04-14-2016, 08:11 AM
  3. How to prevent my Phone from breaking?
    Last Post: 04-12-2016, 05:13 AM
  4. Keep your phone naked or protected it with case?
    Last Post: 04-11-2016, 04:00 AM
  5. How to stop automatic updates?
    Last Post: 04-11-2016, 03:36 AM
