Recovering Photos from Battery Dead S6 edge
After a nasty drop into the toilet, my S6 edge works perfectly fine apart from the battery that is completely dead. Functionality is fine if plugged into a charger, but if I remove the charger from my phone then the phone immediately dies, and the power from my pc's USB isn't enough to keep the phone alive to allow me to get the files off the phone. Is there an easy way to upload and retrieve all my photos to be accessed? When I select all my photos and hit share, it only allows me to upload 500 photos at a time. Thanks for the advice in advance. Much appreciated.
Re: Recovering Photos from Battery Dead S6 edge
Use WiFi File Transfer. Keep the phone powered with the charger.
