A
AC Question
My s5 works properly on -91dbm and receives all calls and msgs .. but my s7 edge is showing no network at same same spot on same sim and same reception -91dbm ? does s7 edge needs more reception to work ? or its antenna is inferior?
i am using the one with exynos processor
