How to control s3 using s5
A
AC Question
I want to play pandora with my Samsung s3 and control the phone using my s5. How can I do this?
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Run a VNC server on the S3 and a VNC client on the S5. (I assume that if you can hear the music, both phones can use the same wifi connection.) If you search the play store for vnc, you'll find a number of apps - even Team Viewer should work.
