A
AC Question
I have found answers that say: go to phone > tap three-dot drop down > last option in the menu will be Call settings, which will take you into the Call subsection of the Settings app. In call settings, call blocking — called call reject here — will be the first item in the Incoming call section. None of this is listed. I have looked around on the phone and can not locate any way to block calls.
Any help would be greatly appreciated.
Drea
Drea
