Not able to receive calls, see notifications, buttons on home screen not working
1) Cant drag down my Notifications , Quick setting menu
2) Unable to receeve calls or any kind of notification
3) Two buttons on Home scree (except "Back") are not working.
Did tried : Setting -> Catche Clear
Did tried : "Wipe Catche Partition"
Did tried : restarting phone
Can't do factory reset (need Internal Storage Data)
Re: Not able to receive calls, see notifications, buttons on home screen not working
Hi, can't you back up the internal storage data before the factory reset? have you tried starting the phone up in safe mode to see if a 3rd party app is causing the issue?
ahhhh this exact thing is happening to me. I cant receive calls, the home button does not work, and I cant access my drop down menu. How did you fix it? I can not do a factory reset, and my internal storage is full even though I uninstalled every single app I had in attempt to revive it. help!
