My Samsung Galaxy s6 edge Plus is draining it's battery due to android os. Any fixes?
A
AC Question
My Samsung Galaxy S6 edge plus is draining it's battery from the Android os. My phone has been fine than a few months ago it started draining the battery. Then it stopped. Now it started again a few days ago. How do I fix this. I've tried and nothing seems to work. Please help.
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,388
254
83
A simple Reboot or Cache Partition wipe will sometimes fix that, or it will settle eventually by itself. Otherwise, consider your Awakes, Syncing, Background App activity, and Location Reporting.
Sleezzyy21
