I have a samsung galaxy Note 4, i use the stylus a lot and can be very helpful. There are lots of different drawing applications but i was wondering if there are any applications which allows you to make notes, draw or anything when you are on any screen without having to close and open another application. Im not sure if this can already be done on a Note 4 but cannot find any applications.
Any help would be great.
Thank you in advanced.
