1. AC Question's Avatar
    I bought it a couple of days ago and it charged fine. Now when i try to charge the case itself, it will not charge, and theres no indication that it is charging. But the case recognises that a usb cable has been plugged in because it pauses wireless charging as soon as i try to charge case.
    07-01-2016 05:50 PM
  2. the tall guy's Avatar
    Hi, have you contacted the seller as you might have a faulty device?
    07-11-2016 04:23 AM
  3. ian_369's Avatar
    Hi. Happens to me too. And I have too. And the interesting thing is after a few days it will return to normal and get back to charging
    09-13-2016 06:29 AM
  4. Rodrigo Guandelini Vianna's Avatar
    Same to me, for the third time already. Its so frustating. You need to wait for the battery to unload.
    10-05-2017 04:57 PM
  1. Turning My Old S4 Into a Glorified MP3 Player; Should I Root it?
    By NateHevens in forum Samsung Galaxy S4
    Last Post: 07-05-2016, 01:17 AM
  2. Replies: 1
    Last Post: 07-01-2016, 10:39 PM
  3. Replies: 1
    Last Post: 07-01-2016, 05:07 PM
  4. what is safe to disable with disable pro for samsung
    By kittykattn in forum Ask a Question
    Last Post: 07-01-2016, 05:02 PM
  5. Replies: 1
    Last Post: 07-01-2016, 04:43 PM
