Problem with WiFi after display replacement on a android phone
A
AC Question
Hi guys,
i recently replaced an LCD because of broken glass on my Lenovo S60. The process went great but after that i noticed i cannot connect to any WiFi. Phone finds all wifi networks with a good signal strength but there is an "WIFI AUTHENTIFICATION ERROR" with any wifi i try to connect. I tried hard reset and some other stuff but it didnt work.
Do you think it can be software issue or i just ****ed up the wifi during replacement of LCD?
Thank you very much for help, have a nice day
filiphanak
hmm, thank you for a reply, i thought WiFi/BT module is part of the motherboard, isn't it? But MAC adress is showing up, and i BT can be turned on, i can try tomorrow its functionality.
EDIT: MAC adress is showing up but IP adress is not showing up, i dont know if it is normal onr not :)
Thank you :)
