A
AC Question
Unlocked the bootloader of my moto x pure and flashed twrp on it. I also installed cyanogenmod 13 onto my phone and everything was working fine, up until I tried using the encrypt feature in the cyanogenmod settings. I started the process, but after over 36 hours of it not finishing and staying in the booting screen I realized there was a problem. I cut the failed process short and from then on my phone would only ever stay in that same screen when powered it on. I tried restoring a backup as well as reinstalling the system, but when I try restoring it says there is an
"Error opening: '/data' (I/O error)".
When I try reinstalling cyanogenmod, twrp says it is successful but it stays in a bootloop, permanently showing the picture of the cyanogenmod guy.
Thank you so much in advance!
