1. AC Question's Avatar
    Hello people, I bought a used G900F, then after installing and uninstalling supersu my phone decided to crap it self out, my G900F came with the wrong firmware, it had the Verizon 5.0.1 Firmware installed (G900VVRU2BOG5)
    but on the about device screen it showed me mine was ( G900FXXU1BOC7 )
    Untill now I have tried everything, my only remaining option is Odin, what firmware should I flash, Verizon because it came installed with it, or the normal one because thats what it should have. PLEASE HELP people I will really appreciate your help. thank you.
    08-16-2016 01:01 PM
  1. why is my samsung j3 taking ages to charge
    Last Post: 08-16-2016, 04:04 PM
  2. CNN's Take on Duo
    By Aquila in forum Google Duo
    Last Post: 08-16-2016, 01:55 PM
  3. Opening Youtube links on mobile site instead of Youtube app?
    By Noca1986 in forum Samsung Galaxy S7
    Last Post: 08-16-2016, 12:41 PM
  4. Samsung S4 and My For Sync not working after recent update
    Last Post: 08-16-2016, 12:27 PM
  5. Replies: 0
    Last Post: 08-16-2016, 12:05 PM
