1. AC Question's Avatar
    Wifi shows "Connected" seconds later "Connection Unavailable"..
    09-04-2016 03:28 AM
  2. Techtein's Avatar
    Have you done any troubleshooting? If yes, can you please share them?
    Is it just happening with one or multiple devices?
    You can try the following steps mentioned below.
    1. Turn off the phone completely and then turn it back on
    2. Forget and reconnect to WiFi network
    3. Reboot your modem/router, if this is happening on all devices
    4. Does your phone connect to just one/two networks i.e. 2.4/5GHz SSID? Is it happening on both?
    09-07-2016 04:23 PM
  1. Why Is The Computer Not Detecting My Device (ASUS ZenFone 5)
    Last Post: 09-22-2016, 08:58 AM
  2. Thinking of Switching from the Note 7
    By ILowry82 in forum OnePlus 3 & 3T
    Last Post: 09-10-2016, 08:53 AM
  3. Why are we facing screen ovalay error message on our phones
    By Davidmonster7739065549 in forum Ask a Question
    Last Post: 09-04-2016, 07:05 AM
  4. Replies: 0
    Last Post: 09-04-2016, 02:16 AM
  5. What is this; "POP UP; TOUCH WIZ HOME IS DISABLED? "
    Last Post: 09-04-2016, 01:58 AM
