1. AC Question's Avatar
    Hello everyone
    I have Samsung Galaxy Note 5 (Model: SM-N9208 Dual Sim) i have recently got problem with battery drain. i did everything like factory reset and upgrade the system but still i have problem with battery life. i fully charged the phone and overnight (9 hours) i lost more 40% of battery no apps installed it is completely fresh.
    Thanks,
    09-04-2016 05:04 AM
  2. Aaurezi1's Avatar
    Yes sir this is a very common problem in marshmallow I recommend you to downgrade from marshmallow to lollipop for a while... the reason of draining battery is Android OS stay awake option.. so the only where to get a better battery life is to downgrade to lollipop...
    09-13-2016 04:26 AM
  1. Replies: 3
    Last Post: 04-19-2018, 03:05 AM
  2. Huawei Honor 4x wont turn on
    Last Post: 09-10-2016, 02:33 PM
  3. Zack from JerryRig explains why the Note7 battery may explode.
    By D13H4RD2L1V3 in forum Samsung Galaxy Note 7
    Last Post: 09-07-2016, 06:51 AM
  4. Contact on home page capability disabled
    By Michael526 in forum Samsung Galaxy A5
    Last Post: 09-04-2016, 06:46 PM
  5. Why does my note 3 say charging paused battery temp to low
    Last Post: 09-04-2016, 04:29 AM
