1. AC Question's Avatar
    Hey, i bought a brand new Moto G4. Everything went fine untill i plugged my Headset (Hyperx Cloud 2) and things started to get "bizarre".
    The audio works perfectly as long as my phone is still, if im carrying it in my pocket or something like that, its almost impossible to have audio on the headset because it keeps losing connection with the phone.
    My Cloud 2 works perfectly on my old Lg G3, an Iphone SE and PC, so they are not the problem.
    Also, i plugged some cheaper earphones into the G4 and somehow, they work perfectly fine.
    Im thinking on getting a jack splitter because im almost sure that the problem is the Cloud 2 Jack not fitting right but im not sure if it will work. What do you guys think?
    I hope this doesnt end being to difficult to read/understand, english is not my first language.
    09-04-2016 08:24 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Sometimes headphone plugs can be a pretty tight fit. Make sure it's pushed all the way in--you should feel or hear it click into place.
    09-04-2016 10:26 PM
  1. Google pictures uploading problems
    By einajr in forum Moto Z
    Last Post: 09-07-2016, 11:48 PM
  2. Authentication problem after 10 minutes of using WiFi
    By Inuya5ha in forum Legacy Android & Other OS's
    Last Post: 09-04-2016, 09:19 PM
  3. How can I use an OTG USB drive in Moto G4?
    Last Post: 09-04-2016, 08:21 PM
  4. Has anyone had problems with the Gear update on your smartphone?
    By doveivy1060 in forum Samsung Galaxy S7 edge
    Last Post: 09-04-2016, 07:33 PM
  5. Replies: 2
    Last Post: 09-04-2016, 06:01 PM
