1. AC Question's Avatar
    1) Is there a way to keep my note 5 unlocked when it's plugged in?
    2) I use Nova Launcher if it matters. Is there a way to get notifications on my lock screen? i hear them when they come in, but they do not show.
    3) Is there a "best" battery app? I struggle getting thru a full day on 1 charge? i realize it's 95% personal preference but I have to believe there has to be an app that actually does do a better job than others when it comes to saving battery life.
    4) When using Bluetooth (Plantronics PLT Voyager Pro). Whenever I make a call it defaults to regular phone use. I have to manually press the bluetooth icon in call to get it to switch to the device.
    Thanks in Advance.
    09-09-2016 07:41 AM
  2. Claude Speed's Avatar
    Thanks in Advance.
    1) No (unless with Tasker, maybe)
    2) What type of lockscreen security are you using?
    3) Not sure
    4) Not sure either
    09-09-2016 07:49 AM
  1. Question About Quick Charging
    By The Harrington in forum Axon 7 & Axon 7 mini
    Last Post: 09-10-2016, 06:47 AM
  2. Replies: 1
    Last Post: 09-09-2016, 11:08 AM
  3. Replies: 0
    Last Post: 09-09-2016, 07:30 AM
  4. Replies: 0
    Last Post: 09-09-2016, 06:54 AM
