1. AC Question's Avatar
    My battery is below 15 percent again (because the battery staying power is really terrible) and literally EVERY 20 SECONDS I get an alert about the battery that tells me the battery is low.
    It's not only annoying, it wastes battery power, which is ironic. How do I stop this notification without totally turning it off? Or even if I have to turn it all the way off?
    09-11-2016 12:46 AM
  2. Tim1954's Avatar
    Yes, avoid all CM apps like the plague! If you're running Marshmallow, you can kill all notifications from all apps...
    09-11-2016 07:49 AM
  1. Replies: 2
    Last Post: 09-18-2016, 10:09 PM
  2. Why did I lose my email
    Last Post: 09-11-2016, 12:36 AM
  3. Replies: 1
    Last Post: 09-10-2016, 11:43 PM
  4. Replies: 0
    Last Post: 09-10-2016, 11:38 PM
