1. AC Question's Avatar
    I'm trying to update my phone because the normal update file is corrupt. Android won't let me re-download it so I had to wipe the cache partition. Now it won't install because the file is missing but the system thinks its there. What mess...
    So I'm trying to make ntr do the update. I go thru all the normal steps and it does all the work but never updates anything?
    I have the nexus 5.1.0 installed and I just want to update it to anything above. I tried 5.1.1 and here is the log
    Flash Stock + Unroot [WugFresh Development]
    target didn't report max-download-size
    sending 'bootloader' (2264 KB)...
    OKAY [ 0.075s]
    writing 'bootloader'...
    OKAY [ 0.284s]
    finished. total time: 0.361s
    rebooting into bootloader...
    OKAY [ 0.002s]
    finished. total time: 0.002s
    < waiting for any device >
    sending 'radio' (45537 KB)...
    OKAY [ 1.442s]
    writing 'radio'...
    OKAY [ 2.491s]
    finished. total time: 3.934s
    OKAY [ 0.002s]
    finished. total time: 0.003s
    Creating filesystem with parameters:
    Block size: 4096
    Blocks per group: 32768
    Inodes per group: 7168
    Inode size: 256
    Journal blocks: 2240
    Label:
    Blocks: 143360
    Block groups: 5
    Reserved block group size: 39
    Created filesystem with 11/35840 inodes and 4616/143360 blocks
    erasing 'cache'...
    OKAY [ 0.041s]
    sending 'cache' (10984 KB)...
    OKAY [ 0.350s]
    writing 'cache'...
    OKAY [ 0.593s]
    finished. total time: 0.984s
    rebooting...
    finished. total time: 0.001s
    Can anyone help me figure out what is the hold up here?
    09-16-2016 06:20 PM
  1. Replies: 9
    Last Post: 05-12-2017, 08:22 AM
  2. Using S7 Edge as loaner..not liking
    By spasell in forum Samsung Galaxy Note 7
    Last Post: 09-20-2016, 09:33 PM
  3. Can I simply use fingerprint to unlock (no swipe)
    Last Post: 09-17-2016, 09:15 AM
  4. Replies: 1
    Last Post: 09-16-2016, 06:59 PM
  5. Replies: 1
    Last Post: 09-16-2016, 03:32 PM
