1. Nastybloodlust's Avatar
    Does launchers like nova launcher drain battery? I need a icon pack but i gotta install a launcher to do that....
    09-18-2016 10:35 AM
  2. Tim1954's Avatar
    Nova launcher doesn't use much juice on my device... Insignificant
    09-18-2016 09:12 PM
  3. Morty2264's Avatar
    I feel like some may take out a small bit of your battery; but if you're worried, just download the launcher and icon pack you want and then check your battery usage stats over the course of a 24-hour period and see if there's a difference! It may depend on the individual launcher, as well.
    Laura Knotek likes this.
    09-18-2016 09:44 PM
  1. Replies: 4
    Last Post: 05-22-2019, 11:26 AM
  2. If you are using Action Launcher 3, a quick question on deleting apps
    By JeffACastro in forum Samsung Galaxy S7 edge
    Last Post: 09-18-2016, 10:33 AM
  3. droid maxx can I over charge battery
    Last Post: 09-18-2016, 08:34 AM
  4. Why does freezing Google Pay Services remove google accounts
    Last Post: 09-18-2016, 07:42 AM
  5. Why is my P9 Plus battery draining so fast?
    Last Post: 09-18-2016, 06:05 AM
