1. AC Question's Avatar
    I am using Samsung S7 for last one month. I have noticed
    1. When I am sitting in my room, then the battery drains as usual.
    2. But when I walk with the phone in my pocket the battery drains really really quick.
    I saw the battery usage one of my friend who uses Samsung s6, it also situation as mine. Can anyone please give me a solution for this.
    09-19-2016 06:03 PM
  2. Tim1954's Avatar
    If you check the battery log, it will show you where the power is going... Be sure to put your screen to sleep before you pocket the device!
    09-20-2016 12:13 AM
  1. Replies: 3
    Last Post: 09-30-2016, 07:04 PM
  2. S6 Active has partial black screen after being rinsed with water
    By Heidi Graham in forum Samsung Galaxy S6 active
    Last Post: 09-23-2016, 03:46 AM
  3. Replies: 3
    Last Post: 09-19-2016, 08:48 PM
  4. Replies: 0
    Last Post: 09-19-2016, 05:29 PM
  5. Replies: 0
    Last Post: 09-19-2016, 05:20 PM
