1. AC Question's Avatar
    Cell phone is recharging very slowly. System information says "to get faster charging use original equipment--but I am. Samsung phone is plugged into the original Samsung battery charger.
    09-25-2016 02:03 PM
  2. anon(9983233)'s Avatar
    I would suggest that IF you haven't actually turned off the device, I would do then connect and charge.. What tends to happen if the device is left on, apps running in the back ground etc can and will drain the battery even before the battery has been completely charged. So when ever you're going to charge your device, simply turn it off completely then connect the USB power cord to a wall socket or surge protection unit and allow the device to charge and display the charging meter.
    09-25-2016 02:48 PM
  1. Replies: 2
    Last Post: 10-06-2016, 07:40 PM
  2. Shattershield: Peace of mind
    By Connert in forum Moto Z
    Last Post: 09-27-2016, 10:05 AM
  3. I have lost the circle of apps
    By AC Question in forum Samsung Galaxy S6
    Last Post: 09-26-2016, 09:16 AM
  4. Green Battery Icon
    By scott15851 in forum Samsung Galaxy Note 7
    Last Post: 09-25-2016, 11:00 AM
  5. Replies: 2
    Last Post: 09-25-2016, 09:35 AM
