1. AC Question's Avatar
    I have a Moto X Pure and was using a power saving app when it completely screwed up my user interface. I was granting the app extra permissions for power saving when my phone suddenly went into this mode where it vibrates and highlights every icon when I press on it. I have to double click the app to launch and most apps do not work properly. I can't even swipe to scroll down so I cannot even get into a reset option.
    Is this some kind of blind mode? How do I turn it off or do a reset if I cannot swipe?
    10-01-2016 07:57 AM
  2. Tim1954's Avatar
    Try holding the power and volume up buttons in for around 20 seconds and that should reboot the device without wiping any data. If that doesn't help try safe mode - - - - https://motorola-global-portal.custh...0,9541/kw/safe
    10-01-2016 09:17 PM
  1. No sounds on any apps.
    Last Post: 10-04-2016, 07:14 PM
  2. Replies: 1
    Last Post: 10-01-2016, 02:57 PM
  3. Replies: 1
    Last Post: 10-01-2016, 11:20 AM
  4. Replies: 2
    Last Post: 10-01-2016, 06:51 AM
  5. Replies: 0
    Last Post: 10-01-2016, 06:39 AM
