A
AC Question
I am not familiar with MicroSD card so this may be a stupid question. I have purchased a SanDisk Ultra 64GB UHS-I/Class 10 Micro SDXC Memory Card (SDSDQUAN-064G-G4A) that comes with an adapter for my Samsung Galaxy Avant and it is working fine when I plug that in (without the adapter of course) to my phone. However, if I plug in the same MicroSD card onto my PC's card reader via the adapter, I notice that 1) all the data I stored on the card via my phone are not found although certain folders (and empty folders only) do exists 2) OS (Windows 7) only recognizes the card has about 1MB in size versus nearly 60GB on my phone. However the content of the card is not the same when it was plugged on the phone vs. on my computer? BTW, if I connect my phone with the card plugged in to the same PC via the phone's cable, Windows is able to read the content correctly. I would like to be able to use my MicroSD card on both my phone and any other devices that accepts SD/SDHC card (through the adapter) simultaneously, is that possible?
