1. AC Question's Avatar
    Hi all,
    I just bought an S7 Edge and when I use it under sunlight wherever my fingers shadow hits it changes the color of the screen. I'm not sure how it works but I think if I use Facebok under shadow it becomes bluish and if I use whatsapp it becomes greenish. Can anyone help me explain what's going on?
    10-06-2016 07:55 AM
  2. Rukbat's Avatar
    Your finger is mostly transparent to red light (that's how a Pulse-Ox works), so you're blocking some colors of light and not others. What ends up showing depends on what you started with.
    10-06-2016 11:44 AM
  3. ibrahim vasija's Avatar
    So you mean that my screen needs to behave like that, and it's normal? also what does Pulse-Ox have to do with my screen and it's colors?
    10-07-2016 06:15 AM
  4. Rukbat's Avatar
    Just using the Pulse-Ox as an example of your finger being semi-transparent to red.
    If the problem is what I said (it may not be - I'd have to have the phone in my hand in sunlight to make sure), you'll have to put up with it.
    10-07-2016 08:38 AM
  1. is Droid Turbo 2 get nougat 7.0?
    Last Post: 10-06-2016, 01:12 PM
  2. Replies: 1
    Last Post: 10-06-2016, 10:48 AM
  3. It's an Android version 4.1.2
    Last Post: 10-06-2016, 09:48 AM
  4. Why is my phone has lost connection with one specific contact
    Last Post: 10-06-2016, 08:05 AM
  5. my screen is all white on my zte f555 how can i fix it
    Last Post: 10-06-2016, 06:12 AM
