1. AC Question's Avatar
    i am new here.i think it is the only place where i might get my answer.because even google doesn't have answer of my problem
    problem is:
    i have a mobile with fixed battery and power button is broken .i went to repairing center but they said its is irreparable.so i used to turn it on by using volumes button while charging nut now volume buttons are also broken.i wonder if there is a way to turn it on?mobile is on right now but if it turns off in any situation what to do?any suggestion or help would be admirable and welcomed
    10-06-2016 12:57 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Unfortunately, I think you're out of luck. There are no software commands that can instruct a powered off phone to power up. I suggest getting the button fixed at a repair shop, which probably won't cost too much.
    10-06-2016 03:16 PM
  3. Tim1954's Avatar
    10-07-2016 03:37 AM
  1. Replies: 1
    Last Post: 10-06-2016, 03:26 PM
  2. i lose my cursor on my outlook android app
    Last Post: 10-06-2016, 03:25 PM
  3. Replies: 1
  4. Is Sony SmartWatch 3 compatible with Samsung galaxy s6
    Last Post: 10-06-2016, 12:43 PM
