1. AC Question's Avatar
    Hi,
    I have a Motorola Nexus 6, which I usually charge with the stock turbo charger that came in the box, but the problem is that it heats my phone upto 49 degree C when charging but that heating happen only for like 45 mins and once its charged upto 80% the heat dissipates and phone charges normally. Few days ago I bought a Samsung Wireless Qi charger thinking it may not heat the phone even though it may charge the phone slowly. But what I am seeing is that the phone still heats upto 47 Degree C and it takes longer time to charge which means the phone remain heated for a longer time. So which approach of charging would be best for me to have a longer battery life?
    Thanks
    10-10-2016 04:29 AM
  2. kicsy023's Avatar
    I think it is normal. Fast charging is more lies your battery. You should to use fast charger when you need some power quickly, in every other case use your factorial charger.
    10-10-2016 02:43 PM
  1. Fast charging no longer fast
    By PeakyBlinder in forum Samsung Galaxy Note 7
    Last Post: 10-10-2016, 01:24 PM
  2. Replies: 7
    Last Post: 10-10-2016, 12:08 PM
  3. Replies: 1
    Last Post: 10-10-2016, 07:24 AM
  4. Replies: 2
    Last Post: 10-10-2016, 05:14 AM
  5. Replies: 1
    Last Post: 10-10-2016, 04:19 AM
