A
AC Question
I have an lg g4 stylus that restarted on its own, and when it turned back on, it went in to this weird state.
the only button that works from the three buttons in the bottom, is the "back" button, the "home" button and the other one won't work.
when I scroll down the notification bar, it says "no notifications" even though I have notifications, there are no longer the options to controll brightness, or to turn on\off the wifi, internet, bluethooth, rotation and more.
I read online that when this happens, you need to enable developer options and change something there (not sure what)- and I tried to enable it by going to settings- about phone- software- build number, and pressing it 7 times, normally that would make me a developer, but it didn't work- nothing showed up when I pressed "build number".
can anyone help me enable developer options and get my phone out of this state?
