1. Chaitanya Sharma's Avatar
    I cannot download the mms messages. Can somebody hel' me out. Appreciate it yaw. BTW I'm using the expensive S7 EDGE
    10-11-2016 01:29 PM
  2. the tall guy's Avatar
    Hi and welcome to AC have you spoken to your carrier? they might have disabled this feature.
    10-18-2016 04:47 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Is your mobile data turned on? MMS requires mobile data to be on -- it doesn't use voice signal or wi-fi.
    If you didn't get the phone directly from your carrier, you might have to check the APN settings to make sure they're configured correctly.
    10-18-2016 04:52 AM
  1. Sorry, You Cannot Add this Image to Your Message
    By shandycat in forum Ask a Question
    Last Post: 10-18-2016, 05:03 AM
  2. Why can't i view/download Yahoo Mail attachments?
    Last Post: 10-18-2016, 04:41 AM
  3. Problems downloading any apps on my Galaxy S5
    Last Post: 10-11-2016, 03:59 PM
  4. Replies: 2
    Last Post: 10-11-2016, 10:12 AM
