1. AC Question's Avatar
    I Bought a new moto g 4 plus phone 15 days back and I am facing above mentioned issue.
    When ever I click on upper volume or increase volume on screen it throws system UI stopped responding error, after which everything closes. I need to unlock phone and get in back to normal ..
    Rebooted, Cleared cache and temp memory.
    Quiet frustrating ..Any ideas how to resolve this ?
    10-11-2016 09:33 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Safe Mode, which temporarily disables all 3rd party apps. https://motorola-global-portal.custh...p/30,6720,9686
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    10-12-2016 02:11 AM
  1. Stuck on SAMSUNG after attempt cache wipe
    By dianehelen in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 11-03-2016, 08:08 PM
  2. Replies: 6
    Last Post: 10-13-2016, 12:59 PM
  3. How to set a sound when email arrives while tablet is off?
    Last Post: 10-12-2016, 01:58 AM
  4. Replies: 0
    Last Post: 10-11-2016, 08:17 PM
  5. Moto G 2014 - System Update
    By SRFast in forum Moto G (2014)
    Last Post: 10-11-2016, 07:09 PM
