A
AC Question
Anyone encountered this with the battery indicator. Voltage suddenly drops to -8% with and indicated battery temperature near -450F?! I tried to post a screen shot that shows how the voltage and temp look like a saw tooth (up & down, up & down) but can't post in this format. After performing a soft reset it indicates normally then a few hours later it does the same thing all over again.
I've tried totally draining then recharging a few times. Also cleared cash along with a factory reset as well as disabling apps and booting in safe mode. All with no change when phone is soft reset to normal operation.
Internet searches have revealed nothing on this subject and I am totally puzzled.
