1. AC Question's Avatar
    Hello,
    I'm having major issues with my Nexus 5. The Camera app says it "couldn't connect to the camera". When I tried using another camera app, only the front camera works. Won't even show show the button to switch to rear camera. My flash doesn't work either when I try using it with a flashlight app, it says "hardware doesn't support LED".
    I went to a T-Mobile store and had them check it out. They couldn't figure it out either, and they think it's a software issue since after a factory reset, the Camera app wasn't even installed/enabled.
    So. it seems like my rear camera and flash have been completely disabled by the latest Android upgrade. Please help.
    -pd
    10-17-2016 11:26 AM
  2. belodion's Avatar
    Does this persist in Safe Mode?
    10-17-2016 01:15 PM
  3. greenplastic's Avatar
    Tried that. Safe Mode didn't change a thing. Is there some other setting that's disabling the camera?
    10-17-2016 03:15 PM
  4. Muhammad Ovais's Avatar
    having same issue, did you got any solution on this.
    01-24-2019 04:42 AM
  5. belodion's Avatar
    Perhaps it's hardware failure of the camera module.
    01-24-2019 05:47 AM
  1. Why does "tag not supported" keep popping up on my LG4?
    Last Post: 07-30-2018, 07:56 AM
  2. Backup and restore homescreen layout after factory reset
    By smooth4lyfe in forum Samsung Galaxy S7 edge
    Last Post: 05-14-2018, 03:51 PM
  3. Samsung 'S Planner noti. not shown' annoying notifications
    By Marcus Kenyon in forum Android 6.0 Marshmallow
    Last Post: 12-09-2016, 03:39 PM
  4. I swear, if this phone doesn't work...
    By miyanc in forum Google Pixel & Pixel XL
    Last Post: 10-19-2016, 06:11 PM
  5. Replies: 0
    Last Post: 10-17-2016, 10:36 AM
