1. AC Question's Avatar
    My phone's Screen takes 43% of my battery while it's been on 0% brightness and at no automatic brightness. Plus there is something called Android system that takes 11% of my battery. I tried to drain my battery fully and then I tried plugging it in so it could charge but it doesn't charge. I put it on charge for two days straight and it only charged 3%. It shows that it will be fully charged in 9 hours but it doesn't charge that fast.
    10-17-2016 01:36 PM
  2. belodion's Avatar
    Screen normally tops the list of battery usage. Android System may also be high without indicating anything abnormal.
    Try a different charging lead, and make sure your USB port is undamaged.
    10-17-2016 02:10 PM
  3. ManiacJoe's Avatar
    If you don't actually need the GPS system running, turn it off for a noticeable power savings.
    10-17-2016 06:24 PM
  1. Replies: 20
    Last Post: 01-10-2017, 12:19 PM
  2. Replies: 1
    Last Post: 10-17-2016, 11:08 PM
  3. where is call settings on my samsung 5
    Last Post: 10-17-2016, 05:31 PM
  4. Replies: 1
    Last Post: 10-17-2016, 02:12 PM
  5. Replies: 0
    Last Post: 10-17-2016, 01:33 PM
