1. AC Question's Avatar
    but when you turn it on it shows its not dead
    10-18-2016 02:06 PM
  2. belodion's Avatar
    A faulty battery, perhaps.
    10-18-2016 02:44 PM
  3. immobile's Avatar
    Today I just started having that same problem with my Note 4. It happened right after foolishly downloading this "network booster" . I've done a partition cache wipe before so with the charger plugged in it brought into the boot mode, or whatever you call it, then I did another wipe, don't know if i needed to but I confirmed it, selected reboot and it came back to normal. But if and when I would unplug it started with the reboot dance. Then I put in a fresh battery and had no problems. Until it hit a bit over 40%. So I don't think it was that app, not that I'm going to read download it so I think it's the batter. It used to do it at a little over 20% but all of a sudden it started with this. I might do a factory reset to see if that helps plus clean the terminal connections on the batteries with first like a pencil eraser then maybe alcohol. My Laser on my Ruger lc9 was going out so I disassembled it to change out the batteries and first I tried cleaning them like I said and put them back in and is was brighter than ever. But anyways I think it's a battery and or the charging system in the phone. I sure wish that Note 7 worked out...
    belodion likes this.
    10-18-2016 03:03 PM
  4. belodion's Avatar
    Does it persist in Safe Mode? Worth a try perhaps.
    Less likely, but possible perhaps....a bad SD card?
    Both unlikely I think but difficult to see what it could be.
    10-18-2016 07:32 PM
  5. immobile's Avatar
    Both batteries were doing it. One @40% and the second at Full charge, but stayed on until I unplugged the charger then good night , it started the reboot dance. Did a factory reset and all's O.K. now. Ya might want to try that providing your still having the problem. Good luck
    10-20-2016 06:10 AM
  1. Need help, I mess up my screen resolution with adb shell.
    Last Post: 10-19-2016, 01:05 AM
  2. How do you get Windows XP SP3 to read a HTC Desire 526?
    Last Post: 10-18-2016, 05:50 PM
  3. My pictures show up on my phone, but not on the computer.
    Last Post: 10-18-2016, 05:39 PM
  4. Note 4 hard reset
    Last Post: 10-18-2016, 02:45 PM
  5. Replies: 0
    Last Post: 10-18-2016, 01:36 PM
