1. AC Question's Avatar
    Hello,
    my girlfriend has a Huawei P8 lite and suddenly her phone started draining battery drastically fast - 100% of battery lasts only for 13h uptime.
    I have turned on developer tools (after wipe + factory reset + no apps installed) and the cpu load shows values around 35/35/35.
    I have tried multiple apps showing what other apps are draining battery, but there's no app significantly draining battery.
    I am out of options now, does anyone ever had similar issue and have had resolved it somehow?
    Thank you guys
    10-19-2016 03:54 PM
  2. melkornemesis's Avatar
    10-19-2016 03:55 PM
  3. belodion's Avatar
    Welcome as a new member.
    Did the battery usage stats indicate nothing unusual?
    10-19-2016 05:10 PM
  4. Morty2264's Avatar
    Welcome! As belodion stated, what do your battery diagnostic stats indicate?
    10-19-2016 05:24 PM
  5. melkornemesis's Avatar
    Hey guys, thanks for the warm welcome
    Is there an app I need to install or something already built-in I could use to check battery diagnostic stats?
    I was going through various settings recently, performing factory reset (2x), wiped cache, deleting google backup so it doesn't install previously installed applications after factory reset, battery calibration. I don't know if it has something to do with it, but I remember installing "Glympse" app to my girlfriend's phone and it could have started by around that time. But I've removed the app immediatelly.
    Thankies
    10-20-2016 01:17 AM
  1. Replies: 1
    Last Post: 10-20-2016, 09:14 AM
  2. 2 yrs old battery...
    By Jason Benoit in forum Samsung Galaxy Note 4
    Last Post: 10-19-2016, 08:40 PM
  3. Battery Life - tested
    By Wazzupp2016 in forum LG V20
    Last Post: 10-19-2016, 05:18 PM
  4. How do I fix my battery life on Galaxy tab 3?
    Last Post: 10-19-2016, 01:55 PM
  5. i cannot reinstall candy crush on my Huawei mediapad T1 8.0
    Last Post: 10-19-2016, 08:03 AM
