1. X-Nemesis's Avatar
    When I scan for and then click on my PC to connect, it prompts me with a username/password pop-up. OK, so I put in my Routers info but the login just vanishes and reappears prompting me to login again.
    I tried my Windows 10 username/password but with the same result.
    Any advice?
    10-22-2016 11:14 AM
  2. Rukbat's Avatar
    Make sure you're using the right case for all letters in the Windows password. (Forget the router's password - that's not what it's looking for.) And make sure it's an Administrator password - a guest password won't work.
    Laura Knotek likes this.
    10-22-2016 03:54 PM
  3. skyguitarman's Avatar
    I was having the same problem. I solved it by going into Network and Sharing Center>Change advanced sharing settings>All networks>Password protected sharing. Click "Turn off password protected sharing". You should also make sure that the drive/folders that you want to access are set for sharing.
    11-26-2016 10:13 AM
  1. Jumps to home screen while playing a game
    By jl1959 in forum Samsung Galaxy Note 5
    Last Post: 10-24-2016, 01:11 PM
  2. Can i downgrade s5 neo to kitkat
    Last Post: 10-22-2016, 03:10 PM
  3. How to enter download mode? (vol+ wont work)
    Last Post: 10-22-2016, 03:08 PM
  4. upgrade to S7 edge (lease) or another Note 4 (insurance)
    By mgiven in forum Samsung Galaxy S7 edge
    Last Post: 10-22-2016, 02:49 PM
  5. Replies: 1
    Last Post: 10-22-2016, 11:16 AM
